Herb Lee
#1 Posted : Tuesday, July 24, 2012 7:57:43 AM(UTC)
Herb Lee
Evaporator motor does not run. The motor is #AP3797248. I put 12 volts to the motor and no results. The motor plug has 4 wires and the frig plug has 3 wires, white,red, and pink. I have 13.53 volts across the white and red wires and 3.67 volts across the white and pink wires,but the voltage goes down to zero after about 15 seconds on the white to pink connection. About an hour later I measured voltages again and got 8.87 volts across white and red and 8.82 volts across the white and pink wires. I know the motor is bad, but is there anything else that could be wrong?
#2 Posted : Wednesday, July 25, 2012 1:35:05 AM(UTC)
Your original motor assembly AP3743432 shows a four pinn connector and the replacement AP3797248 also shows a four pin connector.
See if this new motor can replace the existing one in the housing. If so, I would replace the motor with the new one and also replace the motherboard.
GE Motherboard (Refrigerator & Freezer Repair)
by Quackula100 7/10/2020 8:24:31 PM(UTC)
New motherboard, now compressor not working (Refrigerator & Freezer Repair)
by Jeanebk 6/19/2020 4:36:51 PM(UTC)
Replace motherboard after power outage. (Refrigerator & Freezer Repair)
by Airjglo 4/2/2020 12:59:06 PM(UTC)
Need help with GE side by side, motherboard model. (Refrigerator & Freezer Repair)
by kctyphoon 3/8/2016 4:13:51 PM(UTC)
Clicking after replacing motherboard (Refrigerator & Freezer Repair)
by ClicknFridge 1/19/2016 5:16:55 AM(UTC)
Replaced motherboard/control board (Dishwasher Repair)
by ambyrlynne 7/1/2015 6:24:37 PM(UTC)
Motherboard has a burn (Refrigerator & Freezer Repair)
by randymarcell 6/11/2015 10:48:44 AM(UTC)
Need help with motherboard connectors GE Profile (Refrigerator & Freezer Repair)
by MadmanArctica 10/23/2014 8:39:22 PM(UTC)
GE Frig Inop - Motherboard? (Refrigerator & Freezer Repair)
by civilized_hillbilly 12/3/2013 2:12:45 PM(UTC)
changing motherboard on ge side-by-side (Refrigerator & Freezer Repair)
by av8or 9/10/2013 2:19:18 PM(UTC)
After replacing motherboard temperature drops to 50 degrees (Refrigerator & Freezer Repair)
by AcuraNC 6/11/2013 1:43:09 AM(UTC)
Herb (Refrigerator & Freezer Repair)
by Herb Hawkins 3/19/2013 2:38:27 PM(UTC)
Not cooling, clicking from motherboard (Refrigerator & Freezer Repair)
by Jcc4507fly 10/8/2012 6:44:32 PM(UTC)
motherboard diagram needed (Refrigerator & Freezer Repair)
by TSCHMELTER 6/19/2012 11:16:22 AM(UTC)
Replacing GE refrigerator evaporator motors and motherboards (Refrigerator & Freezer Repair)
by richappy 5/18/2012 3:06:01 PM(UTC)
