mjp3475
#1 Posted : Tuesday, July 24, 2012 4:38:59 AM(UTC)
mjp3475
Hello all. A friend of mine has an Amana ACS3350AS gas range. They are having issues with the control panel shutting off when operating the oven (as similarly documented by several people on the forums).
The way they get the oven to stay on during operation is to take an ice pack (one that you would use on a sprained ankle), wrap it in foil, and place it over the control panel. This leads me to believe that the panel is OK, but excess heat is causing it to shut off.
So the other day while they were cooking, I noticed that the oven door does not completely close tightly all the way into the cavity ... the hinges seem weak. With the door "closed," there is a lot of hot air escaping out the top of the cavity, but when I push and hold the door closed, there is no heat escaping anymore. Would this excess heat be tripping a limit switch in the way of this heat & shutting off the control panel?
I had been doing a bit of reading in this thread ( http://forum.appliancepartspros...-shuts-off-when-hot.html ) about limit switches, cooling, etc, but I'm wondering given the behavior I've seen so far with the oven door, if I'm better off replacing the hinges first before going to the switches/fan to fix the control panel issue (the hinges are probably easier to replace)?
Your thoughts?
Thanks in advance!
-MP
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
front load amana door misalign (Washer Repair)
by wilsonjiaho 5/17/2024 1:02:16 PM(UTC)
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Amana top load washer model NTW4600 (Washer Repair)
by Guest 5/2/2024 8:47:15 AM(UTC)
Amana washer load like a flying airplane (Washer Repair)
by wilsonjiaho 4/30/2024 1:48:54 PM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Amana compressor issues (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:42:43 PM(UTC)
Amana fridge warm, freezer cold (Refrigerator & Freezer Repair)
by agdodge4x4 12/25/2023 6:22:47 PM(UTC)
NTW4516FW3 Amana Top Loader Washer (Washer Repair)
by KMags 11/28/2023 4:52:44 PM(UTC)
Amana AFI2538AEB refrigerator ice dispenser door opens and closes continually (Refrigerator & Freezer Repair)
by Guest 9/30/2023 6:59:28 AM(UTC)
Amana dryer motor growl at startup (Dryer Repair)
by Guest 9/21/2023 3:35:28 AM(UTC)
Amana fridge SX26VE door seals, hens teeth? (Refrigerator & Freezer Repair)
by Guest 8/31/2023 10:58:17 AM(UTC)
Amana washer not filling properly (Washer Repair)
by carcajou 5/12/2023 10:53:05 AM(UTC)
