Replacement parts for WHIRLPOOL TEDX640PQ1 | AppliancePartsPros.comHere is the wiring diagram
http://www.servicematters.com/d...0Sheet%20-%208576793.pdfCould be a number of things.
First check that you have 240 volts at the plug.
Flip the breaker off/on slowly a couple times, sometimes you can loose half the line without tripping the breaker. Better yet check it with a meter.
On this unit the timer uses 240 volts so if the timer advances in timed dry mode you have the 240.
Next would be the thermal fuse or the heater itself.
Note the thermal fuse for the heater is Item 6 in the Bulkhead Parts section.
If the fuse is blown clean the interior, including the blower wheel.
Also clean and check the vent system, this is the most common cause of the fuse blowing.
