kevin71
#1 Posted : Thursday, September 17, 2009 3:01:03 PM(UTC)
kevin71
my dryer works but has no heat what is wrong
#2 Posted : Friday, September 18, 2009 2:49:01 AM(UTC)
Replacement parts for WHIRLPOOL TEDX640PQ1 | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/d...0Sheet%20-%208576793.pdf
Could be a number of things.
First check that you have 240 volts at the plug.
Flip the breaker off/on slowly a couple times, sometimes you can loose half the line without tripping the breaker. Better yet check it with a meter.
On this unit the timer uses 240 volts so if the timer advances in timed dry mode you have the 240.
Next would be the thermal fuse or the heater itself.
Note the thermal fuse for the heater is Item 6 in the Bulkhead Parts section.
If the fuse is blown clean the interior, including the blower wheel.
Also clean and check the vent system, this is the most common cause of the fuse blowing.
whirlpool duet electric dryer works but no heat (Dryer Repair)
by sbfire370 4/13/2011 3:24:11 AM(UTC)
Dryer Works But No Heat (Dryer Repair)
by BIL LOGSDON 6/28/2009 7:57:01 PM(UTC)
dryer works but no heat coming out (Dryer Repair)
by villanuevanc 3/15/2009 9:33:01 PM(UTC)
kenmore dryer works but no heat (Dryer Repair)
by RichS 2/12/2008 1:57:00 PM(UTC)
gas dryer works but no heat (Dryer Repair)
by johnfox 1/22/2008 2:48:22 PM(UTC)
Frigidaire Gas Dryer works but No Heat, Why?? (Dryer Repair)
by mvetri 11/2/2007 1:28:35 PM(UTC)
