dccmw
#1 Posted : Thursday, January 24, 2008 4:48:19 PM(UTC)
dccmw
kenmore fridge has stopped the light stills comes on when opening the door but the fridge and freezer are not getting cold and the pump is not kicking on ?
#2 Posted : Friday, January 25, 2008 1:38:51 PM(UTC)
If everything besides the interior lights is dead, then most likely the refrigerator stuck in the defrost mode.
Locate the shaft on the defrost timer (#23 on the break down diagram) and slowly turn it CW.
If, after it clicked, the compressor kicked on then the defrost timer is bad and has to be replaced.
- The part number for the defrost timer is AP2111929
dccmw
#3 Posted : Saturday, January 26, 2008 1:56:54 PM(UTC)
dccmw
Gene,
Well i tried turning the deforst timer and it did click as you said but nothing happened i tried several times but nothing i think the darn fridge is all done i don't know.Any other ideas ?
#4 Posted : Saturday, January 26, 2008 4:35:43 PM(UTC)
Try to bypass the cold control (aka thermostat).
If it would not help then probably the compressor is bad.
old kenmore fridge click (Refrigerator & Freezer Repair)
by rleescott 7/4/2024 7:07:45 AM(UTC)
Kenmore Fridge Supco (Refrigerator & Freezer Repair)
by Tony442 6/23/2024 8:34:01 PM(UTC)
Kenmore fridge Model 106.59422800 (Refrigerator & Freezer Repair)
by mamon 6/11/2022 11:14:00 AM(UTC)
Kenmore Fridge problem (Refrigerator & Freezer Repair)
by johnp1984 10/26/2021 5:25:46 AM(UTC)
KENMORE Fridge Wont Start Till I punch the thermostat Control (Refrigerator & Freezer Repair)
by kami009 7/5/2019 10:21:20 AM(UTC)
Kenmore fridge does nothing (Refrigerator & Freezer Repair)
by checkcutter 6/12/2017 1:56:47 PM(UTC)
Kenmore fridge and freezer not holding temperature (Refrigerator & Freezer Repair)
by jandonian 12/12/2015 7:48:59 AM(UTC)
Kenmore fridge cold freezer not cold enough (Refrigerator & Freezer Repair)
Belarus Jasonywu 8/6/2015 2:05:17 PM(UTC)
Defrost Problem Kenmore Fridge (Refrigerator & Freezer Repair)
by smackover 7/14/2015 4:13:25 PM(UTC)
Kenmore fridge not cold enough (Refrigerator & Freezer Repair)
by benbenherenow 4/9/2015 1:26:32 PM(UTC)
Kenmore Fridge freezes everything! (Refrigerator & Freezer Repair)
by AnneMX5 10/6/2014 5:47:14 PM(UTC)
Kenmore Fridge sorta cool, freezer very cold. (Refrigerator & Freezer Repair)
by pir123 9/1/2014 9:43:02 PM(UTC)
Kenmore Fridge doesn't stay cold (Refrigerator & Freezer Repair)
by grobles 8/24/2014 11:42:25 AM(UTC)
Kenmore fridge barely making ice (Refrigerator & Freezer Repair)
by David_in_Idaho 8/21/2014 9:16:20 AM(UTC)
Kenmore Fridge Door not sealing (Refrigerator & Freezer Repair)
by frogprincess2 8/7/2014 9:31:09 PM(UTC)
