roylance
#1 Posted : Thursday, July 19, 2012 1:04:11 PM(UTC)
roylance
Dryer was being used this morning then when the wife tried another load it would not start. I have checked continuity on the Thermal fuse and door switch. ALso checked the push to start switch. No problems found. What is next? Thanks for any help you can provide.
Simon / APP Team
#2 Posted : Thursday, July 19, 2012 4:14:31 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
There are two thermal fuses before the motor (heater fuse). Check them both.
Check if the appropriate button pushed all the way at the selector switch.
Here are the breakdown diagrams and http://www.appliancepartspros.c...odel.aspx?model_id=45255
Thank you. Post the results.
Simon.
roylance
#3 Posted : Thursday, July 19, 2012 4:35:14 PM(UTC)
roylance
Thanks for quick response. Don't know why but I put it all back together and it is now running? We will see for how long. I have a feeling I'll be back. But before I come back again I will check those two fuses.
#4 Posted : Friday, July 20, 2012 1:46:09 AM(UTC)
If it is running then the fuses are OK.
Once blown they stay blown.
If you shut the breaker off when you worked on the unit then that may have been the problem.
Sometimes you can loose half the line without actually tripping the breaker.
Another possibility is the motor. It has an internal thermal protect. If it overheats the protect opens and you then have to wait for the motor to cool down (protect resets) before it will start again.
Looking to tune up our Maytag Neptune Dryer (Dryer Repair)
by bassett72 2/14/2018 4:51:00 AM(UTC)
by 3pinballs 9/10/2014 11:33:08 AM(UTC)
how to take apart front face of maytag neptune dryer to get to coils (Dryer Repair)
by m218perez 6/18/2014 12:25:10 PM(UTC)
Maytag Neptune Dryer LOUD High Pitch Screeching (Dryer Repair)
by audioarch 2/28/2014 3:53:13 PM(UTC)
Small Paint Brush Stuck in Maytag Neptune Dryer Lint Trap (Dryer Repair)
by PVBSJ 11/20/2013 5:57:47 PM(UTC)
Maytag Neptune Dryer Doesn't Start on /off (Dryer Repair)
by torrealtl1 11/13/2013 9:39:51 AM(UTC)
Maytag Neptune Dryer doesn't work (Dryer Repair)
by pulsar2121 11/3/2013 3:41:03 PM(UTC)
maytag neptune dryer issues (Dryer Repair)
by blueovalfever 10/14/2013 6:25:43 AM(UTC)
Maytag Neptune Dryer wont do anything (Dryer Repair)
by heg0423 8/21/2013 10:26:37 PM(UTC)
Maytag Neptune Dryer not starting (Dryer Repair)
by buckeye597 2/17/2013 4:09:06 PM(UTC)
Need Service Repair Manual Maytag Neptune Dryer MDE4000AYW (Dryer Repair)
by Paul02 8/12/2012 2:21:22 PM(UTC)
Maytag Neptune Dryer Code FE (Dryer Repair)
by hamrepairman 7/6/2012 6:28:38 PM(UTC)
Maytag Neptune Dryer - heat will not stay on (Dryer Repair)
by creeker69 5/24/2012 6:51:55 PM(UTC)
by crutecaroline 2/11/2012 8:46:12 AM(UTC)
my maytag neptune dryer does not work (Dryer Repair)
by markwarnick@att.net 2/5/2012 11:33:27 AM(UTC)
