roylance
#1 Posted : 13 years ago
roylance
Dryer was being used this morning then when the wife tried another load it would not start. I have checked continuity on the Thermal fuse and door switch. ALso checked the push to start switch. No problems found. What is next? Thanks for any help you can provide.
Simon / APP Team
#2 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
There are two thermal fuses before the motor (heater fuse). Check them both.
Check if the appropriate button pushed all the way at the selector switch.
Here are the breakdown diagrams and http://www.appliancepartspros.c...odel.aspx?model_id=45255
Thank you. Post the results.
Simon.
roylance
#3 Posted : 13 years ago
roylance
Thanks for quick response. Don't know why but I put it all back together and it is now running? We will see for how long. I have a feeling I'll be back. But before I come back again I will check those two fuses.
#4 Posted : 13 years ago
If it is running then the fuses are OK.
Once blown they stay blown.
If you shut the breaker off when you worked on the unit then that may have been the problem.
Sometimes you can loose half the line without actually tripping the breaker.
Another possibility is the motor. It has an internal thermal protect. If it overheats the protect opens and you then have to wait for the motor to cool down (protect resets) before it will start again.
Looking to tune up our Maytag Neptune Dryer (Dryer Repair)
by bassett72 7 years ago
by 3pinballs 11 years ago
how to take apart front face of maytag neptune dryer to get to coils (Dryer Repair)
by m218perez 11 years ago
Maytag Neptune Dryer LOUD High Pitch Screeching (Dryer Repair)
by audioarch 11 years ago
Small Paint Brush Stuck in Maytag Neptune Dryer Lint Trap (Dryer Repair)
by PVBSJ 11 years ago
Maytag Neptune Dryer Doesn't Start on /off (Dryer Repair)
by torrealtl1 11 years ago
Maytag Neptune Dryer doesn't work (Dryer Repair)
by pulsar2121 11 years ago
maytag neptune dryer issues (Dryer Repair)
by blueovalfever 11 years ago
Maytag Neptune Dryer wont do anything (Dryer Repair)
by heg0423 12 years ago
Maytag Neptune Dryer not starting (Dryer Repair)
by buckeye597 12 years ago
Need Service Repair Manual Maytag Neptune Dryer MDE4000AYW (Dryer Repair)
by Paul02 13 years ago
Maytag Neptune Dryer Code FE (Dryer Repair)
by hamrepairman 13 years ago
Maytag Neptune Dryer - heat will not stay on (Dryer Repair)
by creeker69 13 years ago
by crutecaroline 13 years ago
my maytag neptune dryer does not work (Dryer Repair)
by markwarnick@att.net 13 years ago
