heg0423
#1 Posted : Wednesday, August 21, 2013 10:26:37 PM(UTC)
heg0423
I have a Maytag Neptune MDE6800 dryer and when I went to use it the display would not light up and it will not do anything. The inside light will light up but that is it. What could it be? Has the circuit board gone bad?
HumboldtRepairMan
#2 Posted : Thursday, August 22, 2013 6:59:37 PM(UTC)
HumboldtRepairMan
unscrew the keypad off and make sure you have 120v at the main board if you do then it's most likely a bad main board........if not it's a bad keypad try the main board testing first.
heg0423
#3 Posted : Thursday, August 22, 2013 7:34:46 PM(UTC)
heg0423
I checked it and I have 120 at both of the black wires at the back of the board.
HumboldtRepairMan
#4 Posted : Thursday, August 22, 2013 7:36:50 PM(UTC)
HumboldtRepairMan
Try and replace the main board then order it from this site and if it doesn't work you can return it.
