Dove
#1 Posted : Saturday, July 14, 2012 6:35:16 AM(UTC)
Dove
Have a whirlpool front load duet. I get the FH code on some settings and other settings the locked, wash and add garment will be lit and not wash properly.
sidfink43
#2 Posted : Sunday, July 15, 2012 4:48:34 PM(UTC)
sidfink43
If you look under the top or inside the lower service panel you will find some tech notes that will tell you what the error code means, and will also tell you how to put the machine into a diagnostic mode and do some testing.
Good luck, hope this helps.
Whirlpool Duet washer FH code (Washer Repair)
by farmgirl 1/17/2017 7:14:25 PM(UTC)
fh code on whirlpool duet (Washer Repair)
by keithdouglas 3/5/2016 11:56:19 AM(UTC)
Whirlpool Duet GHW9250 FH code (Washer Repair)
by duanec 7/7/2013 6:03:46 PM(UTC)
Maytag front loader FH code (Washer Repair)
by tamiwalnut 1/28/2010 1:42:29 PM(UTC)
Fh Code (Washer Repair)
by GWILLIAMS 10/16/2009 7:53:28 AM(UTC)
Fh Code No Or Insufficient Water Supply (Washer Repair)
by meeksj 6/20/2009 9:01:06 PM(UTC)
Kenmore HE3 FH code early in cycle (Washer Repair)
by st_pinetree 2/6/2009 7:10:22 AM(UTC)
fh code (Washer Repair)
by wannnabetech 10/28/2008 10:01:25 AM(UTC)
Duet Washer displays FH code (Washer Repair)
by kaahurley 6/20/2008 7:37:24 AM(UTC)
