pfoss76
#1 Posted : Tuesday, July 10, 2012 2:21:43 PM(UTC)
pfoss76
replaced door Latch None Of Functions Work When The Start Is Pressed. Looked For The Wiring Diagram On The Kick Plate Nothing
Could Not Find Tech Sheet They Make Reference To. I Gather This Is
The Function Panel Or Control Board Around ($180.00) Giving Me Problems,
Serial Number-2215674cx
Paul
#2 Posted : Wednesday, July 11, 2012 1:14:19 AM(UTC)
Replacement parts for Maytag MDB5600AWB DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
See the attachment for the missing tech sheet.
If the unit has no signs of life then I would check the wire nut connection to the house power.
They can sometimes come loose/open over time.
Better yet measure the voltage at the board.
If it does have some sings of life but the keys do nothing, then the normal way to troubleshoot is to measure/check the keypad with a meter. If it checks out OK then replace the control board. Still a bit of a crap shoot but your odds are better.
Try to get into the diagnostics.
File Attachment(s):
MDB5600.pdf (249kb) downloaded 5 time(s).
pfoss76
#3 Posted : Wednesday, July 11, 2012 8:40:24 AM(UTC)
pfoss76
Prior owner had put tech sheet in with manuals which I found, rinse lite when pressed lights. Tried pin test since field tests failed am confused about pin number layout on flat ribbon cable left is #1 or from right is #1. I am down to display panel or control panel problem. Need pin # layout.
THANKS-----pAUL:mad::confused:
GE Cafe dishwasher will not start (Dishwasher Repair)
by Guest 5/18/2023 11:11:14 PM(UTC)
Samsung dishwasher will not start wash cycle (Dishwasher Repair)
by relentless85 8/12/2016 5:57:33 PM(UTC)
Dishwasher Will not start (Dishwasher Repair)
by BajaScout 10/31/2015 12:54:52 PM(UTC)
kitchen aide dishwasher will not start (Dishwasher Repair)
by Edwin L Davis 4/26/2015 6:02:45 PM(UTC)
Kitchenaid dishwasher will not start and makes humming noise (Dishwasher Repair)
by jbritton@evisionsys.com 9/28/2014 9:08:26 AM(UTC)
Maytag dishwasher will not start (Dishwasher Repair)
by timwhitten 3/24/2014 2:15:09 PM(UTC)
Dishwasher will not start (Dishwasher Repair)
by genegilbert 11/18/2012 6:45:22 AM(UTC)
by okchiller1 10/25/2012 6:39:31 AM(UTC)
Frigidaire Dishwasher will not start wash cycle (Dishwasher Repair)
by dcarney01 6/4/2012 6:40:55 PM(UTC)
by BROOKSHEA 5/30/2012 6:17:17 AM(UTC)
KitchenAid Dishwasher will not start (Dishwasher Repair)
by tydlackab 3/12/2012 10:32:28 AM(UTC)
by DDDDDD 9/29/2011 1:32:59 PM(UTC)
Dishwasher will not start. (Dishwasher Repair)
by DAWOLFESR 8/24/2011 7:38:52 AM(UTC)
Maytag Legacy Series dishwasher will not start (Dishwasher Repair)
by gideonse 8/22/2011 7:14:33 AM(UTC)
by ta22676 5/16/2011 6:11:34 PM(UTC)
