twilliams01
#1 Posted : Saturday, September 12, 2009 11:42:34 AM(UTC)
twilliams01
I am trying to diagnosis my prblem with my dryer while i have a few days off and before it gets colder and cant hang out clothes. We replaced the thermister and did not work, cleaned out all inner parts of dryer, as well. It runs will not heat , when in the normal load mode after about dive to ten min. AD shows up on display screen. Then it shuts off and lights underneath all blink ? Will someone please help me fix this.
glen65
#2 Posted : Saturday, September 12, 2009 12:03:44 PM(UTC)
glen65
Before you go any further you need to make sure that you are
getting 240 volts AC where the cord connects at the dryer.
You would "Carefully" check the outside two terminals with an
AC Voltmeter. Your dryer wont look like this one, but the way
the power cord connects to most all brands is pretty much the same.
UserPostedImage
Samsung dryer wont heat (Dryer Repair)
by Dabenthall 12/19/2016 10:51:29 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
by bennieman 11/9/2016 10:30:17 AM(UTC)
by mkrason 12/18/2015 3:28:25 PM(UTC)
Maytag Dryer wont heat (Dryer Repair)
by Rescal 8/18/2015 5:23:15 PM(UTC)
by highcountry71 8/16/2015 8:42:56 AM(UTC)
Kenmore 80 Series...Dryer Wont Heat... Tested/continuity good (Dryer Repair)
by xtacbyme 6/3/2015 7:57:15 PM(UTC)
dryer wont heat in timed dry mode (Dryer Repair)
by thildy 5/7/2015 2:26:44 PM(UTC)
by Jim Winkels 4/5/2015 5:08:25 PM(UTC)
Whirlpool dryer wont heat (Dryer Repair)
by ekujustice 4/2/2015 4:47:16 PM(UTC)
Dryer wont heat on timed dry and works sometimes on auto setting (Dryer Repair)
by AJM57 3/14/2015 8:45:13 AM(UTC)
by Nmiles 11/24/2014 2:22:06 PM(UTC)
electric dryer wont heat (Dryer Repair)
by janietodd 9/24/2014 11:10:25 AM(UTC)
ge dryer wont heat (Dryer Repair)
by appliancerepairguy 9/13/2014 11:31:54 PM(UTC)
Dryer wont heat - element and fuses/limiters fine (Dryer Repair)
by watsonwabbit69 6/19/2014 10:41:14 AM(UTC)
