frank616
#1 Posted : Thursday, June 14, 2012 1:22:16 PM(UTC)
frank616
my coils froze up 2 months ago. defrosted unit and restarted one day later. exactly 2 months later having same problem. I'm told that this unit has a defrost board, and that would most likely be the culprit. I"m sure the defrost heater is working, only because it has been fine for 2 months with no problem. Any advise would be greatly appreciated.. This is a french door style. what really makes me crazy is that it is just over two years old.
Simon / APP Team
#2 Posted : Thursday, June 14, 2012 3:32:12 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely you are right - replace the control board.
The control board Part number: 12868513
Here are the breakdown diagrams and Replacement parts for Whirlpool GX2FHDXVY03 REFRIGERATOR | AppliancePartsPros.com
Thank you. Post the results.
Simon.
PS. do not forget to program the new control.
#3 Posted : Friday, June 15, 2012 12:47:10 AM(UTC)
I am assuming that you checked that the evaporator coils are heavily frosted over. Just to be sure that it is not same symptoms, different cause.
As Simon said the control board is at the top of the list but you may also want to check the defrost thermostat.
I could not find it in the parts breakdown but it will be clipped to the evaporator coils.
If it is deformed/bulged replace it.
Check it with a meter.
When frozen it should be 0 ohms.
At room temperature it should be 56,000 ohms.
File Attachment(s):
GX2FH.pdf (258kb) downloaded 5 time(s).
Side by side coils freezing up (Refrigerator & Freezer Repair)
by delifolk1964 6/30/2016 10:07:19 AM(UTC)
Coils freezing up on upper portion of LG refrigerator (Refrigerator & Freezer Repair)
by fll_LG 1/10/2016 1:46:38 PM(UTC)
GE gsh22kgpa fridge, coils freezing up (Refrigerator & Freezer Repair)
by crcorc 9/25/2015 7:07:16 AM(UTC)
GE dual evap Profile PS model, coils freezing over (Refrigerator & Freezer Repair)
by half-past 8/4/2015 6:35:49 PM(UTC)
freezer coils freezing up (Refrigerator & Freezer Repair)
by jpnemco 5/6/2014 7:25:45 AM(UTC)
Coils freezing over popping GFI couple times a night (Refrigerator & Freezer Repair)
by dawgface21 10/12/2013 4:51:01 AM(UTC)
HELP!!! GE Side by side coils freezing up (Refrigerator & Freezer Repair)
by billda 5/14/2013 4:42:45 AM(UTC)
coils freezing (Refrigerator & Freezer Repair)
by daniel gangloff 9/24/2012 8:37:20 AM(UTC)
Coils freezing (Refrigerator & Freezer Repair)
by MWeeks 7/12/2012 5:45:42 PM(UTC)
GE side-by-side evap. coils freezing, fridge freezing at bottom and not cold at top (Refrigerator & Freezer Repair)
by jttaylor 1/23/2012 11:24:01 AM(UTC)
by gatlin95 5/12/2011 3:47:51 PM(UTC)
Frigidaire Side by Side Coils Freezing Over (Refrigerator & Freezer Repair)
by jeanie_mcc@yahoo.com 9/30/2009 10:08:13 AM(UTC)
AC coils freezing up (Heating, Ventilation, and Air Conditioning (HVAC))
by somethinggrl 6/28/2009 8:50:24 AM(UTC)
coils freezing up in freezer and frig temps warm (Refrigerator & Freezer Repair)
by dhofer 6/2/2009 6:08:17 AM(UTC)
Evaporator coils freezing over,replaced defrost timer (Refrigerator & Freezer Repair)
by crnmd 5/8/2009 2:46:05 PM(UTC)
