must9450
#1 Posted : Friday, September 11, 2009 1:27:16 PM(UTC)
must9450
When GE profile dishwasher is running it's leaking from bottom..Upon inspection it appears to be leaking from the front on the pump housing where the motor shaft goes in. I'm not positive about the leak location, the water is coming off the bottom mount screw for the motor. Is this an easy fix? I havn't pulled the dishwasher out of the cabinet,yet. I'm just trying to help elderly parents out. THANK-You for all of your help. Steve:confused:
maintainitcos
#2 Posted : Friday, September 11, 2009 11:05:44 PM(UTC)
maintainitcos
It sounds like its leaking out of the shaft seal, thats fairly common on those units, AP631386 is the part you will need to get . It is a service kit that includes the impeller and seals.
You will need to pull the unit out from under the cabinet, and carefully flip it on its back to service it properly.
#3 Posted : Saturday, September 12, 2009 7:22:12 AM(UTC)
Try using a small mirror and a flashlight to locate the exact location of the leak.
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
ge dishwasher leaking at bottom (Dishwasher Repair)
by Jerry7235 10/31/2013 1:48:10 PM(UTC)
GE Dishwasher leaking at shaft near solenoid valve (Dishwasher Repair)
by e-man 8/14/2011 6:55:10 PM(UTC)
GE Dishwasher Leaking Out Through Water InFeed during aggitation (Dishwasher Repair)
by andrewmcc 3/26/2011 3:20:29 PM(UTC)
GE dishwasher leaking at bottom right front door (Dishwasher Repair)
by ZincWhiskers 3/23/2010 12:03:20 PM(UTC)
GE Dishwasher Leaking (Dishwasher Repair)
by katiedbell 11/29/2009 4:50:08 PM(UTC)
GE Dishwasher leaking (Dishwasher Repair)
by _Joe_ 8/6/2009 8:52:48 AM(UTC)
by leland48 4/15/2009 7:32:25 AM(UTC)
GE Dishwasher Leaking from fitting below washer arm (Dishwasher Repair)
by DeG6 11/25/2008 11:59:59 PM(UTC)
GE dishwasher leaking (Dishwasher Repair)
by Chuck Hamby 11/9/2008 10:33:16 AM(UTC)
