BCe
#1 Posted : Monday, June 4, 2012 7:04:56 PM(UTC)
BCe
Unbeknownst to me, found the dishwasher had been leaking for sometime. Looks like water is dripping from around the water intake valve area. Anyone experience this or ever change this part? I am thinking given the age of the unit it is not something major? Thanks!
#2 Posted : Tuesday, June 5, 2012 1:31:26 AM(UTC)
Here are hour parts
Replacement parts for GU2455XTSS models | AppliancePartsPros.com
Remove the kick plate and determine what exactly is leaking.
Could be the valve itself but could also be one of the water hose connections.
A small mirror and a flashlight can be useful here.
If you click on a parts picture a new page will open often with a Q&A section about that part.
Looks simple enough to replace.
Undo the screw and move the valve assembly to the right to un-clip it.
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
Water leaking from Kenmore Elite 10657789700 (Refrigerator & Freezer Repair)
by Guest 6/8/2024 12:11:48 PM(UTC)
Samsung french door bottom freezer loud buzzing and water leak (Refrigerator & Freezer Repair)
by surgeslayer2 10/19/2023 3:33:56 AM(UTC)
Speed Queen washer water leak (Washer Repair)
by Guest 5/20/2023 4:29:11 PM(UTC)
795.71073.013 Kenmore Refrigerator - Water leaking in the bottom freezer (Refrigerator & Freezer Repair)
by shreshtluthra 3/16/2023 10:21:43 AM(UTC)
LG front load washer water leak (Washer Repair)
by Guest 7/23/2022 11:17:44 AM(UTC)
GE Profile PSHS6PGZBESS water leaking from dispenser (Refrigerator & Freezer Repair)
by Guest 12/30/2021 5:30:45 PM(UTC)
Samsung french door refrigerator water leak (Refrigerator & Freezer Repair)
by rodey01 12/22/2021 5:20:31 AM(UTC)
Whirlpool fridge water leak not solvable with ptrap (Refrigerator & Freezer Repair)
by richdell 5/2/2021 5:33:45 AM(UTC)
water leaking inside (Refrigerator & Freezer Repair)
by csegel 7/21/2020 9:15:26 AM(UTC)
water leaking IN to the tub (Washer Repair)
by gabericks 7/5/2020 2:21:45 PM(UTC)
Water leaking from freezer Magic Chef (Refrigerator & Freezer Repair)
by FabianCh 1/7/2020 5:40:04 PM(UTC)
Kenmore - Water leaking from cracked connectors (Refrigerator & Freezer Repair)
by allengl1 8/12/2019 9:02:34 PM(UTC)
Water leaking into Fridge and Freezer (Refrigerator & Freezer Repair)
by HKL64 5/27/2019 4:17:22 PM(UTC)
Water leak after replacing water valve (Refrigerator & Freezer Repair)
by gmanly 4/13/2019 9:06:58 AM(UTC)
