leeke02
#1 Posted : Friday, September 11, 2009 4:09:39 AM(UTC)
leeke02
I just received a replacement timer from AppliancePartsPros and the connections are slightly different then those on the original timer that I am replacing. Specifically on the original timer there is a tan wire that jumps from the top left connector to another connector on the same side of the timer, two connectors down. This appears to be some type of jumper wire, however the new timer that I just received does not have the same second connector that the tan wire is jumped to. Any idea how I am to connect this tan jumper wire on the new timer?
Frank / APP Team
#2 Posted : Friday, September 11, 2009 6:12:30 AM(UTC)
Frank / APP Team
After blowing up the pic of the timer it appears there are two terminals on the tan connector. That would lead me to believe that it's now jumped internally. I also looked at the wiring diagram for the model and the tan serves two purposes inside the timer. I'm sure you'll be fine hooking both tans to the two available spots on the tan marked terminal.
