I am having a problem getting ice and water from the dispenser. It will start to dispense the ice or water then stop. What should I look for?
Groups: APP Team
Hi. If the dispenser light is deeming when the lever is pushed it's the sign of a bad main control board, located at the rear of the fridge under the metal cover. The main control board Part number: WR55X10942
