s_pierce
#1 Posted : Tuesday, May 29, 2012 9:25:09 AM(UTC)
s_pierce
The ice maker quit working on this 20+year old GE refrig. The water dispenser in the door works fine. To check to see if it is the water valve, I disconnected the 2 lines to see if I could swap them out. Unfortunately, they are of different size so there was no way to test. I see where I could check the fill line to see if it is frozen. How do I go about doing that. Are there any instructions posted anywhere?
Aside from the valve or the fill line, is there anything else I should look at?
Thanks for the help!
Simon / APP Team
#2 Posted : Tuesday, May 29, 2012 1:25:31 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You can check the water line by blowing in to it from the back of the fridge.
If you feel OK to work with life electricity you can make a direct test cord by attaching two female contacts to the power cord, connecting them to the water valve solenoid and plug the test cord into the outlet for 3 seconds.
You also may run the continuity test of the solenoid.
To get you the part numbers we need the complete model number. You may find it at the bottom right corner behind the toe grill.
Thank you. Post the results.
Simon.
Samsung side by side refrigerator No water to ice maker (Refrigerator & Freezer Repair)
by mtrafton 5/29/2020 5:25:03 AM(UTC)
No water to ice maker / water works through door (Refrigerator & Freezer Repair)
by mservice 3/15/2019 4:16:54 PM(UTC)
No water to ice maker or door (Refrigerator & Freezer Repair)
by scar1 1/12/2019 12:49:56 PM(UTC)
No Water To Ice Maker (Refrigerator & Freezer Repair)
by Daussie 6/16/2017 6:42:49 AM(UTC)
by Stone JR 8/21/2016 11:25:13 AM(UTC)
No water dispenses, no water to ice maker (Refrigerator & Freezer Repair)
by jeffreyjd@charter.net 2/5/2013 5:17:45 PM(UTC)
by sydnoid 10/22/2012 6:20:09 PM(UTC)
No Water To ice Maker (Refrigerator & Freezer Repair)
by phuluu 6/7/2012 9:34:28 PM(UTC)
by barbaraann 3/26/2012 11:36:20 AM(UTC)
No water to Ice Maker or Door Unit (Refrigerator & Freezer Repair)
by Kevin933 11/30/2011 11:44:20 AM(UTC)
No Water to Ice Maker or Water Dispenser (Refrigerator & Freezer Repair)
by JoeSavo 8/8/2011 1:20:18 PM(UTC)
by tkirsch 6/21/2011 10:54:58 AM(UTC)
Frigidaire No water to ice maker (Refrigerator & Freezer Repair)
by taberd1985 6/12/2011 8:23:55 PM(UTC)
by pwg02001 4/22/2011 10:52:31 AM(UTC)
Kenmore no water to ice maker. (Refrigerator & Freezer Repair)
by JooeII 4/2/2011 10:12:49 AM(UTC)
