My Jennair had some random meat probe plug in error beeps and after a few months of those, it has a F-1 8 error.
I called Jennair and they said it is a short of the membrane switch. I think I see the part on your site (AP4094865).
My question is: If I purchase the part, is it pretty easy to replace or do I need to call a technician. If I can do it, are there instructions that come with the part...
Thanks Prashant
Hi Prashant, If you know how to handle a simple tools then it's not going to be too difficult. You can find the instructions in the Service manual. Most likely the problem is a bad membrane switch which is a part of the control panel, but there is a small chance for the control board (aka a clock) to be bad as well. Here are the breakdown diagrams for the Jenn Air range Model JES9860AAW
Gene,
Thanks for the info. Go back from a trip last night, woke up this morning and a half an hour later, the new part was installed with no problems. the new part has solved the F1-8 problem.
Thanks Prashant
You are welcome. I'm glad you were able to fix it.
