prashant
#1 Posted : Wednesday, September 9, 2009 8:33:49 AM(UTC)
prashant
My Jennair had some random meat probe plug in error beeps and after a few months of those, it has a F-1 8 error.
I called Jennair and they said it is a short of the membrane switch. I think I see the part on your site (AP4094865).
My question is: If I purchase the part, is it pretty easy to replace or do I need to call a technician. If I can do it, are there instructions that come with the part...
Prashant
#2 Posted : Wednesday, September 9, 2009 2:03:31 PM(UTC)
Hi Prashant,
If you know how to handle a simple tools then it's not going to be too difficult. You can find the instructions in the Service manual.
Most likely the problem is a bad membrane switch which is a part of the control panel, but there is a small chance for the control board (aka a clock) to be bad as well.
Here are the breakdown diagrams for the Jenn Air range Model JES9860AAW
prashant
#3 Posted : Sunday, September 13, 2009 12:36:48 PM(UTC)
prashant
Gene,
Thanks for the info. Go back from a trip last night, woke up this morning and a half an hour later, the new part was installed with no problems. the new part has solved the F1-8 problem.
Prashant
#4 Posted : Sunday, September 13, 2009 12:55:48 PM(UTC)
You are welcome. I'm glad you were able to fix it.
