the oven will not work. the processor will not light up.
Can you be more specific on the problem?
You missed a letter between "M" and "0" in the model number. Verify and repost it.
Gene. corrected modle no. sf315pembo. the electrictroic board will not light up. the stove top burners work fine.
I Cant Get My Stove To Work I Have Replaced The Control Panel And It Still Want Work What Should I Do
Originally Posted by: kenrays corrected modle no. sf315pembo. the electrictroic board will not light up. the stove top burners work fine. If there is 120 VAC to the control board then the control board has gone bad and has to be replaced. If you need the correct part number for the control board then post the color of the key pad. Here are the Tech sheet. Gene.
Originally Posted by: lothario I Cant Get My Stove To Work I Have Replaced The Control Panel And It Still Want Work What Should I Do What is the complete model number of the unit? Can you be more specific on the problem? Gene.
