inquisitive
#1 Posted : Friday, May 18, 2012 8:03:26 AM(UTC)
inquisitive
Do I need to pull the range out from the cook island to change the infinite burner switch?
Simon / APP Team
#2 Posted : Friday, May 18, 2012 10:51:37 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely not. If you do it would be just far enough to release the control panel.
Here is the breakdown diagram and Control panel (d146) (d146w) replacement parts for Jenn-Air D146W RANGE- S/C D/I DDRAFT ELE | AppliancePartsPros.com
Thank you.
Simon.
Infinite switch replacement (Oven Repair (including Ranges and Cooktops))
by J_T 9/14/2013 2:43:04 PM(UTC)
Thermador Infinite Switch Replacement (Oven Repair (including Ranges and Cooktops))
by JLondon 4/16/2013 2:17:18 PM(UTC)
Dual Infinite Switch Replacement (Oven Repair (including Ranges and Cooktops))
by ddelling 7/20/2010 8:23:53 AM(UTC)
by david.freeland@sacorp.com 9/24/2008 2:11:48 PM(UTC)
