inquisitive
#1 Posted : 13 years ago
inquisitive
Do I need to pull the range out from the cook island to change the infinite burner switch?
Simon / APP Team
#2 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
Most likely not. If you do it would be just far enough to release the control panel.
Here is the breakdown diagram and Control panel (d146) (d146w) replacement parts for Jenn-Air D146W RANGE- S/C D/I DDRAFT ELE | AppliancePartsPros.com
Thank you.
Simon.
Infinite switch replacement (Oven Repair (including Ranges and Cooktops))
by J_T 11 years ago
Thermador Infinite Switch Replacement (Oven Repair (including Ranges and Cooktops))
by JLondon 12 years ago
Dual Infinite Switch Replacement (Oven Repair (including Ranges and Cooktops))
by ddelling 15 years ago
by david.freeland@sacorp.com 16 years ago
