Background.... - Up to two weeks ago the fridge was working fine. - Then the fridge started to get very cold and ice started to form in the milk. - One week ago the fridge was warm milk definitely was not cold. - I did some checking on the internet and saw that the damper could be an issue. - Definitely no cold air coming through the damper. - Ran the diagnostics and everything checked out the themistors fridge & freezer gave green light. Got a compact mirror and saw that the damper would open and close but was not smooth in the process. - Could gently pry the damper open with a butter knife and feel some air but never felt a lot of air coming through.
Last Thursday... - Unpluged fridge and washed the freezer down. - Took off the back panel and not build up of ice. - Made sure the air flow was not blocked from the freezer to the fridge via damper. - Put the freezer back together - Cleaned the back where the compressor is. - Coils in front were dirty and used a vacuum in reverse to blow it clean had dust everywhere LOL - I plugged it in and almost immediately the freezer dropped to a cold temperature and started making ice again. - Air flow in the freezer is good. - The fridge started to get cold and had good air flow. - Everything seemed back on track. - I also noticed the air flow is strong again.
Yesterday... - Fridge is starting to warm up again. - Freezer is working well and still makes ice and everything is frozen. - Milk is warm again. - Noticed no air flow in fridge - Airflow in freezer is good - I noticed the Damper is closed again and I could gently pry it open and started air flow just not as strong. - Current temperature in freezer after 1 minute on an instant read termometer is -6.5 with a setting of -5 on the control panel - Current temperature in fridge after 1 minute on an instant read termometer is +41 with a setting of +33 on the control panel
Question...
With no ice on the coils and the damper not staying open could it be a faulty damper? and if so, should I also replace the fridge thermostat?
Any other thoughts?
Your assistance is greatly appreciated.
Pj
P.S. Sorry if this is long but wanted to provide as much detail as possible.
Groups: APP Team
Hi. Based on the info you provided I suggest you to replace the air damper control. The damper Part number: 2216112
Originally Posted by: Simon / APP Team Hi. Based on the info you provided I suggest you to replace the air damper control. The damper Part number: 2216112
This thread may relate to my issue with my KSRA25CNSS00 I replaced the damper about 6 weeks ago after having the same symptoms, warm fridge cold freezer no airflow this seemed to have fixed the problem. The problem has returned freezer 3 deg, fridge 47, I have frost on the damper fridge side but the damper seems to be open but not much air flow. When I replaced the damper i did not replace the thermistor. Could this be the problem? Thanks
