Pjrs
#1 Posted : Monday, May 7, 2012 9:16:12 PM(UTC)
Pjrs
Background....
- Up to two weeks ago the fridge was working fine.
- Then the fridge started to get very cold and ice started to form in the milk.
- One week ago the fridge was warm milk definitely was not cold.
- I did some checking on the internet and saw that the damper could be an issue.
- Definitely no cold air coming through the damper.
- Ran the diagnostics and everything checked out the themistors fridge & freezer gave green light. Got a compact mirror and saw that the damper would open and close but was not smooth in the process.
- Could gently pry the damper open with a butter knife and feel some air but never felt a lot of air coming through.
Last Thursday...
- Unpluged fridge and washed the freezer down.
- Took off the back panel and not build up of ice.
- Made sure the air flow was not blocked from the freezer to the fridge via damper.
- Put the freezer back together
- Cleaned the back where the compressor is.
- Coils in front were dirty and used a vacuum in reverse to blow it clean had dust everywhere LOL
- I plugged it in and almost immediately the freezer dropped to a cold temperature and started making ice again.
- Air flow in the freezer is good.
- The fridge started to get cold and had good air flow.
- Everything seemed back on track.
- I also noticed the air flow is strong again.
Yesterday...
- Fridge is starting to warm up again.
- Freezer is working well and still makes ice and everything is frozen.
- Milk is warm again.
- Noticed no air flow in fridge
- Airflow in freezer is good
- I noticed the Damper is closed again and I could gently pry it open and started air flow just not as strong.
- Current temperature in freezer after 1 minute on an instant read termometer is -6.5 with a setting of -5 on the control panel
- Current temperature in fridge after 1 minute on an instant read termometer is +41 with a setting of +33 on the control panel
Question...
With no ice on the coils and the damper not staying open could it be a faulty damper? and if so, should I also replace the fridge thermostat?
Any other thoughts?
Your assistance is greatly appreciated.
Pj
P.S. Sorry if this is long but wanted to provide as much detail as possible.
Simon / APP Team
#2 Posted : Tuesday, May 8, 2012 7:38:40 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Based on the info you provided I suggest you to replace the air damper control.
The damper Part number: 2216112
The thermistor Part number: 2188819
Here are the breakdown diagrams and Replacement parts for Whirlpool KSRA25ILSS01 REFRIGERATOR | AppliancePartsPros.com
Thank you. Post the results.
Simon.
palm9610
#3 Posted : Monday, September 2, 2013 8:41:05 AM(UTC)
palm9610
Rank:: Member
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
This thread may relate to my issue with my KSRA25CNSS00
I replaced the damper about 6 weeks ago after having the same symptoms, warm fridge cold freezer no airflow this seemed to have fixed the problem. The problem has returned freezer 3 deg, fridge 47, I have frost on the damper fridge side but the damper seems to be open but not much air flow. When I replaced the damper i did not replace the thermistor. Could this be the problem?
