My Ref has stopped working all of a sudden, no fan noise but all the lights are lit and no noise at all. i cleaned it up but still no luck, any ideas.
Groups: APP Team
Hi Simon, so it can't be the starter, i have removed that one and it is rattling too, I have removed the control box, what type of jumper cable i need to replace #9.
Groups: APP Team
Hi. INSTALL THE JUMPER BETWEEN TWO WIRES OF THE COLD CONTROL (#9 on the diagram #3). If you don't feel comfortable doing any electrical tests then may be you can run a continuity test, but you'll need a multimeter. If you don't - then get both parts I've listed and replace them one at the time. You can return any unused parts even if they been installed.
Thank you. Post the results.
Simon.
