bdnewy
#1 Posted : Saturday, September 5, 2009 11:11:23 AM(UTC)
bdnewy
Our dryer takes at least 2 cycles to dry 1 load of laundry. It's a kirkland signature by whirlpool...any ideas? Thanks
sidfink43
#2 Posted : Sunday, September 6, 2009 6:35:44 AM(UTC)
sidfink43
Slow drying times are caused by either a failure of the cycling thermostat or the fact that the venting system is obstructed or that the blower is not working correctly.
You will need to open up the dryer and check to make sure the blower wheel/fan is ok. Then clean out the venting system inside the dryer, including the air intake, and also clean out the pipe from the dryer to the outside.
Try it again, this will likely solve your problem.
Kenmore dryer slow to dry (Dryer Repair)
by rdouma 9/10/2014 12:07:00 PM(UTC)
Whirpool Temp Range? Dryer is slow to dry (Dryer Repair)
by StiffNeckRob 3/15/2010 4:38:46 PM(UTC)
Electric Dryer is slow to dry (Dryer Repair)
by amonard 2/9/2010 1:37:57 PM(UTC)
Kenmore 70 series dryer is slow to dry. (Dryer Repair)
by borger10 10/3/2009 7:36:24 AM(UTC)
Maytag Dryer slow to dry and smells like gas inside (Dryer Repair)
by mahoney845 12/10/2008 12:18:49 PM(UTC)
noisey dryer slow to dry (Dryer Repair)
by Don OBrian 9/9/2008 1:21:05 PM(UTC)
