bdnewy
#1 Posted : 15 years ago
bdnewy
Our dryer takes at least 2 cycles to dry 1 load of laundry. It's a kirkland signature by whirlpool...any ideas? Thanks
sidfink43
#2 Posted : 15 years ago
sidfink43
Slow drying times are caused by either a failure of the cycling thermostat or the fact that the venting system is obstructed or that the blower is not working correctly.
You will need to open up the dryer and check to make sure the blower wheel/fan is ok. Then clean out the venting system inside the dryer, including the air intake, and also clean out the pipe from the dryer to the outside.
Try it again, this will likely solve your problem.
Kenmore dryer slow to dry (Dryer Repair)
by rdouma 10 years ago
Whirpool Temp Range? Dryer is slow to dry (Dryer Repair)
by StiffNeckRob 15 years ago
Electric Dryer is slow to dry (Dryer Repair)
by amonard 15 years ago
Kenmore 70 series dryer is slow to dry. (Dryer Repair)
by borger10 15 years ago
Maytag Dryer slow to dry and smells like gas inside (Dryer Repair)
by mahoney845 16 years ago
noisey dryer slow to dry (Dryer Repair)
by Don OBrian 16 years ago
