my ice maker is making ice BUT Barely. the ice looks fine but the sheets are small and I only get a few cubes at a time. the machine will no longer fill up to the top. My husband added coolant (freon) but still this did not help
any suggestions?
thanks Cindy
Groups: APP Team
Hi, Cindy. You need to check several things. If the condenser coils are clean. If the condenser motor runs OK. If the water fills up to the top of the container. If the water runs down the evaporator evenly. Turn the water off and check if the evaporator frosting up evenly. If everything checks OK, than I would suggest to replace the evaporator thermistor. When installing the new one make sure the surface it's attached to is clean of any deposits. The evaporator thermistor Part number: 2217289
I have purchased and changed out the thermistor. the ice that is being made seems to be "larger" or "thicker" than before which is a good thing BUT the machine still doesn't make enough to fill the bucket. just a handful of ice is made daily
any suggestions as to what I should try next?
thanks Cindy
Groups: APP Team
Hi, Cindy.
Have you checked the rest of the things I listed earlier?
Simon.
the evaporator does not frost up evenly, everything else on the list seems to be good
Groups: APP Team
Hi.
I'm afraid there is the sealed system problem and you need a pro to take care of it.
Thank you.
Simon.
sealed system problem meaning I have a coolant leak?
thanks for your help Cindy
