cindyrae
#1 Posted : Tuesday, April 24, 2012 11:14:56 AM(UTC)
cindyrae
my ice maker is making ice BUT Barely. the ice looks fine but the sheets are small and I only get a few cubes at a time. the machine will no longer fill up to the top. My husband added coolant (freon) but still this did not help
any suggestions?
thanks
Cindy
cindyrae
#2 Posted: : Tuesday, April 24, 2012 11:22:48 AM(UTC)
cindyrae
Kuis18nnjb5
Simon / APP Team
#3 Posted : Tuesday, April 24, 2012 3:15:24 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Cindy.
You need to check several things.
If the condenser coils are clean.
If the condenser motor runs OK.
If the water fills up to the top of the container.
If the water runs down the evaporator evenly.
Turn the water off and check if the evaporator frosting up evenly.
If everything checks OK, than I would suggest to replace the evaporator thermistor.
When installing the new one make sure the surface it's attached to is clean of any deposits.
The evaporator thermistor Part number: 2217289
Here are the breakdown diagrams and Replacement parts for Whirlpool KUIS18NNJB5 ICE CUBE MAKER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
cindyrae
#4 Posted : Monday, July 23, 2012 8:40:14 AM(UTC)
cindyrae
I have purchased and changed out the thermistor. the ice that is being made seems to be "larger" or "thicker" than before which is a good thing BUT the machine still doesn't make enough to fill the bucket.
just a handful of ice is made daily
any suggestions as to what I should try next?
thanks
Cindy
Simon / APP Team
#5 Posted : Monday, July 23, 2012 9:50:17 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi, Cindy.
Have you checked the rest of the things I listed earlier?
Simon.
cindyrae
#6 Posted : Monday, July 30, 2012 1:34:31 PM(UTC)
cindyrae
the evaporator does not frost up evenly, everything else on the list seems to be good
Simon / APP Team
#7 Posted : Monday, July 30, 2012 5:05:24 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
I'm afraid there is the sealed system problem and you need a pro to take care of it.
Thank you.
Simon.
cindyrae
#8 Posted : Tuesday, July 31, 2012 7:53:45 AM(UTC)
cindyrae
sealed system problem meaning I have a coolant leak?
thanks for your help
Cindy
