jamc0616
#1 Posted : Thursday, September 3, 2009 6:03:30 PM(UTC)
jamc0616
Serial #GR141133G
Washer fills with water, does not agitate, completes wash cycle, while in the drain/spin cycle it will drain the water, but does not spin. The tub spins freely (by hand) with lid open or shut. Also the timer ticks when it should be spinning on the spin cycle. It is the same issue on all of the spin cycles. Tried unplugging the washer & this did not solve the problem. Can my husband repair this or do I need to call someone? Thank you!
jamc0616
#2 Posted : Thursday, September 3, 2009 7:24:54 PM(UTC)
jamc0616
Originally Posted by: jamc0616 Go to Quoted Post
Serial #GR141133G
PS - green LED flashes once every 6 seconds THANKS!!
110.24622300 direct drive washer wont agitate or spin motor hums (Washer Repair)
by Guest 10/10/2021 7:32:00 PM(UTC)
washer wont agitate or spin (Dishwasher Repair)
by steve2016 4/21/2016 8:12:47 AM(UTC)
my washer wont agitate or spin ULTIMATE CARE ll (Washer Repair)
by ballprez6 12/26/2014 11:12:12 AM(UTC)
GE Profile washer wont agitate or spin, motor will hum (Washer Repair)
by copperman 8/12/2014 4:20:30 PM(UTC)
washer wont agitate or spin (Washer Repair)
by bjsmith7 3/9/2014 7:19:34 PM(UTC)
roper washer wont agitate or spin!!!! (Washer Repair)
by mrbreezio 4/28/2012 12:24:29 AM(UTC)
Kenmore front load washer wont agitate or spin (Washer Repair)
by ebcravens 1/10/2012 2:27:09 PM(UTC)
hotpoint washer wont agitate or spin (Washer Repair)
by bksmith623 10/8/2011 9:14:31 AM(UTC)
GE Washer wont agitate or spin (Washer Repair)
by tinkerbell63 10/4/2011 3:21:59 AM(UTC)
by lpadilla 6/19/2011 10:06:42 AM(UTC)
by mikeyk01 4/19/2011 6:58:18 AM(UTC)
by Chukcharp 1/31/2011 8:57:01 PM(UTC)
Ge Washer Wont Agitate Or Spin (Washer Repair)
by cameo591 11/19/2010 3:31:06 PM(UTC)
washer wont agitate or spin, makes grinding noise (Washer Repair)
by donnascruggs 10/3/2009 9:02:12 AM(UTC)
washer wont agitate or spin out just hums (Washer Repair)
by bobcat1206 7/9/2009 8:53:21 AM(UTC)
