jamc0616
#1 Posted : 16 years ago
jamc0616
Serial #GR141133G
Washer fills with water, does not agitate, completes wash cycle, while in the drain/spin cycle it will drain the water, but does not spin. The tub spins freely (by hand) with lid open or shut. Also the timer ticks when it should be spinning on the spin cycle. It is the same issue on all of the spin cycles. Tried unplugging the washer & this did not solve the problem. Can my husband repair this or do I need to call someone? Thank you!
jamc0616
#2 Posted : 16 years ago
jamc0616
Originally Posted by: jamc0616 Go to Quoted Post
Serial #GR141133G
PS - green LED flashes once every 6 seconds THANKS!!
110.24622300 direct drive washer wont agitate or spin motor hums (Washer Repair)
by Guest 4 years ago
washer wont agitate or spin (Dishwasher Repair)
by steve2016 9 years ago
my washer wont agitate or spin ULTIMATE CARE ll (Washer Repair)
by ballprez6 10 years ago
GE Profile washer wont agitate or spin, motor will hum (Washer Repair)
by copperman 11 years ago
washer wont agitate or spin (Washer Repair)
by bjsmith7 11 years ago
roper washer wont agitate or spin!!!! (Washer Repair)
by mrbreezio 13 years ago
Kenmore front load washer wont agitate or spin (Washer Repair)
by ebcravens 13 years ago
hotpoint washer wont agitate or spin (Washer Repair)
by bksmith623 14 years ago
GE Washer wont agitate or spin (Washer Repair)
by tinkerbell63 14 years ago
by lpadilla 14 years ago
by mikeyk01 14 years ago
by Chukcharp 14 years ago
Ge Washer Wont Agitate Or Spin (Washer Repair)
by cameo591 14 years ago
washer wont agitate or spin, makes grinding noise (Washer Repair)
by donnascruggs 16 years ago
washer wont agitate or spin out just hums (Washer Repair)
by bobcat1206 16 years ago
