I have replaced control panel because the latch had broken!! The machine ran for 2 to 3 loads then quit!!! I replaced with another new conttrol panel and the same thing happened 2 to 3 loads then wont start!!! I can change cycles and the panel lights up, but go out after 30 sec or so. I have checked the switches for cont, and are ok. Is there some type of reset that should be used??? Thanks Ron
Groups: APP Team
Hi. Let's try the following: With the dishwasher in "Quit!!!" position unplug it for a few minutes, then plug it back in. If it will work for a couple of loads and the stops again, then most likely you need to replace the control board. The control board Part number: 99003160
I have cut the power for a few hours and repowered, with same results!!!
Groups: APP Team
Hi.
Replace the control board. You can always return unused parts even if they been installed.
Simon.
