maytagdog
#1 Posted : Monday, April 16, 2012 8:36:47 AM(UTC)
maytagdog
I have replaced control panel because the latch had broken!! The machine ran for 2 to 3 loads then quit!!! I replaced with another new conttrol panel and the same thing happened 2 to 3 loads then wont start!!! I can change cycles and the panel lights up, but go out after 30 sec or so. I have checked the switches for cont, and are ok. Is there some type of reset that should be used??? Thanks Ron
Simon / APP Team
#2 Posted : Monday, April 16, 2012 10:40:00 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Let's try the following:
With the dishwasher in "Quit!!!" position unplug it for a few minutes, then plug it back in.
If it will work for a couple of loads and the stops again, then most likely you need to replace the control board.
The control board Part number: 99003160
Her are the breakdown diagrams and Replacement parts for Maytag MDB6600AWW DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
maytagdog
#3 Posted : Monday, April 16, 2012 11:37:42 AM(UTC)
maytagdog
I have cut the power for a few hours and repowered, with same results!!!
Simon / APP Team
#4 Posted : Monday, April 16, 2012 5:23:19 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Replace the control board.
You can always return unused parts even if they been installed.
Simon.
Maytag Dishwasher wont start (Dishwasher Repair)
by EvieHunter 8/9/2012 11:18:24 AM(UTC)
maytag dishwasher wont start (Dishwasher Repair)
by uglystik 6/4/2012 5:06:57 PM(UTC)
by timbucktoo 8/31/2011 9:40:40 AM(UTC)
Maytag dishwasher wont start (Dishwasher Repair)
by lmfalk 2/17/2011 11:16:55 AM(UTC)
by uglystik 11/7/2009 12:01:29 PM(UTC)
