uglystik
#1 Posted : Saturday, November 7, 2009 12:01:29 PM(UTC)
uglystik
Maytag dishwasher touchpad lights up on all settings except normal but wont start on any lights stay on 30 sec then go off :mad:
#2 Posted : Sunday, November 8, 2009 2:38:57 AM(UTC)
Replacement parts for MAYTAG MDBTT60AWW | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/m...ibrary/docs/16026393.pdf
Try to run the diagnostics.
Try the below cleaning
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
If the above does nothing then check the keypad out using a meter.
If it checks out OK your control board probably needs replacing.
Maytag Dishwasher wont start (Dishwasher Repair)
by EvieHunter 8/9/2012 11:18:24 AM(UTC)
maytag dishwasher wont start (Dishwasher Repair)
by uglystik 6/4/2012 5:06:57 PM(UTC)
by maytagdog 4/16/2012 8:36:47 AM(UTC)
by timbucktoo 8/31/2011 9:40:40 AM(UTC)
Maytag dishwasher wont start (Dishwasher Repair)
by lmfalk 2/17/2011 11:16:55 AM(UTC)
