jennyawilson
#1 Posted : Sunday, April 15, 2012 5:12:30 PM(UTC)
jennyawilson
When i run a load in my dishwasher a film is left on my dishes that are on the bottom rack. Also a good amount of water is left in the bottom of the dishwasher. We just purchased a Gasket for the pump and the flapper for the drain. This did not solve the problem.
What would be the reason why the water is not fully draining?
Is that why the dishes on the bottom rack is left with a film on them?
#2 Posted : Monday, April 16, 2012 3:20:03 AM(UTC)
[COLOR="DarkRed"]What would be the reason why the water is not fully draining?[/COLOR]
Since you replaced the flapper I am assuming that you checked the drain pump to be sure it's impeller was clear/clean.
I would disconnect the drain at the house plumbing and drain it into a pail, this will eliminate the house plumbing as a possible cause.
Be sure to hold the drain line securely in the pail and put a towel over it so it does not splash all over.
A common place for plugs is where the drain line conects to the house plumbing.
If it still does not drain correctly work your way back through the drain system.
If it is all OK then odds are your drain pump needs replacing.
[COLOR="DarkRed"]
Is that why the dishes on the bottom rack is left with a film on them?[/COLOR]
Yes it could be but I cannot say for sure.
A film is often due to hard water so can be related to the type or amount of detergent. Or running without any rinse agent.
I still think the best detergent is the old fashioned powder
DCS (Fisher & Paykel) DD24DV2T7 Two Drawer Dishwasher Not Draining Fully (Dishwasher Repair)
by DCBUS 4/7/2023 5:44:37 AM(UTC)
Inglis dishwasher not draining - trouble removing filter (Dishwasher Repair)
by Guest 2/18/2023 5:24:29 AM(UTC)
Dishwasher not Draining - Frigidaire (Dishwasher Repair)
by Guest 12/10/2022 3:04:30 PM(UTC)
Whirlpool Dishwasher not draining at end of cycle-intermittently (Dishwasher Repair)
by Floyd Pinkerton 9/28/2022 11:07:32 AM(UTC)
Whirlpool dishwasher not draining with diagnostics code 6-4 (Dishwasher Repair)
by dcelbert 12/28/2021 11:04:45 AM(UTC)
GE Dishwasher not draining, no clogs anywhere (Dishwasher Repair)
by DanielWS 9/16/2020 11:32:15 AM(UTC)
Dishwasher not draining fully (Dishwasher Repair)
by ernestcmjr 1/29/2016 12:51:58 PM(UTC)
Kitchenaid dishwasher not draining... (Dishwasher Repair)
by mjl1297 1/19/2016 7:03:55 PM(UTC)
Whirlpool dishwasher not draining (model WDF730PAYB6) (Dishwasher Repair)
by patrick04 12/20/2015 7:40:06 PM(UTC)
Kitchen Aid Dishwasher Not Draining (Dishwasher Repair)
by jrdardano 7/18/2015 1:23:21 PM(UTC)
Dishwasher not draining after cycle (Dishwasher Repair)
by sanjayg1971 7/1/2015 10:37:25 AM(UTC)
Dishwasher not draining (Dishwasher Repair)
by CTLewis 2/23/2014 1:43:26 PM(UTC)
Amana dishwasher not draining completely (Dishwasher Repair)
by dennis728 11/24/2013 4:26:15 PM(UTC)
whirlpool dishwasher not draining (Dishwasher Repair)
by mdauer2002 5/28/2013 1:28:01 PM(UTC)
Dishwasher not draining, hoses/filter are clear (Dishwasher Repair)
by limon 3/1/2013 8:37:12 AM(UTC)
