Maytag Legacy Leaking. Repairman here twice. Said all seals were good. Unable to detect any leaking. My floor says otherwise. Leaks out front during spin cycle and if machine is tilted water also comes out. Leak started small now seems to be larger HELP
check to make sure your waste line is not backing up ... if you are handy lift top and remove front and fill machine with towels and run machine through cycle and watch spin. see if water goes over the top ?
