Last summer the large oven "BAKE" coil in our Thermadore range started working sporatically. We have the large Professional Dual-Fuel model (6 burners). We ordered an new coil from you in August. After you first send the wrong, smaller coil, you sent the right larger one. Our order should be in your records.
I replaced this coil correctly. It worked for a few weeks then the problem reoccurred. My wife found that pushing the "BAKE" button on and off a few times... would get the coil to work.
Now... it doesn't. The coil won't come on We're assuming it's the switch. Can you advise if this is the cause...what part(s) we would need? Also if this is a job I can handle?
Many Thanks for your guidance. Bob & Lee Casazza 321 Boylston Ave., E. #405 Seattle, WA 98102
(206) 860-2060
