petelisam
#1 Posted : Monday, August 31, 2009 4:31:20 PM(UTC)
petelisam
Dryer No Heat, Where To Start First?? It Is A Gas Dyer
SublimeMasterJW
#2 Posted : Monday, August 31, 2009 6:44:33 PM(UTC)
SublimeMasterJW
If the duct fuse next to the control thermostat is open then no power can get to the gas assembly. If the dryer control thermostat is open then no power can get to the gas assembly. So I have 3 pages of repair pix to take a look at:
Dryer fuses and locations
basic gas assembly operation
My take on intermitant gas heating problems
Bonus Info:
Old school dryer manual for whirlpool
kayakcrzy
#3 Posted : Tuesday, September 1, 2009 4:33:24 AM(UTC)
kayakcrzy
Originally Posted by: petelisam Go to Quoted Post
dryer no heat, where to start first?? it is a gas dyer
let me help you out with some technical advise, not a bunch links. the first thing you want to do is take the back off, and there is the thermal fuse. it is white in color, and is about an inch and a half long, by a half inch wide. take the 2 wires off of it. (of course the dryer is unplugged at this time) and put the terminal ends of the wires together, and put some tape around it, so it does not hit metal, and then plug it in and give it a try. if it works, replace the thermal fuse, and do not run the ryer with the fuse jumped out. this is the only thing that stops the dryer from burning down your house. if it does not work you need to let me know if the ignitor comes on, and i will instruct you from there. tom www.applianceeducacator.com/parts.htm
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
