crumb
#1 Posted : Monday, April 9, 2012 6:03:34 PM(UTC)
crumb
I turn my microwave on and the motor runs but no heat and is louder than before. The forums i see say it is the magnetron or a diod, i don't even see that my model has a diod anywhere.
Simon / APP Team
#2 Posted : Monday, April 9, 2012 7:26:11 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The rectifier (diod) #1 at the diagram#1 located at the hi-voltage capacitor.
To check it you MUST first discharge it.Using two crossed screw drivers touch with them each contact at the capacitor.
Take the one rectifier's leg off and with the meter set on highest resistance setting check if there any reading at all.
If there any thing - replace the rectifier.
No reading - check the magnetron.
Take the contacts off the magnetron and check the continuity and then - check if it's "grounded."
If there is continuity to the ground - replace the magnetron.
The rectifier Part number: AP4362626
The magnetron Part number: AP4301392
Her are the breakdown diagrams and Appliance Parts Pros.com Discount Appliance Parts
Thank you. Post the results.
Simon.
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
