Patients
#1 Posted : Sunday, August 30, 2009 5:17:34 AM(UTC)
Patients
I was drying some clothes and it just stop, could it be heater coil,
sidfink43
#2 Posted : Monday, August 31, 2009 12:15:58 PM(UTC)
sidfink43
First check to make sure you have 120v to each side of the connection block. Then unplug the machine and check continuity on the thermal fuse/thermostats. Finally check the door switch and the heating coil.
Good luck.
kayakcrzy
#3 Posted : Tuesday, September 1, 2009 4:48:01 AM(UTC)
kayakcrzy
Originally Posted by: sidfink43 Go to Quoted Post
first check to make sure you have 120v to each side of the connection block. then unplug the machine and check continuity on the thermal fuse/thermostats. finally check the door switch and the heating coil.
good luck.
part number needed. la-1053. that is thermal fuse kit. it is located where the element is. it has 2 white wires coming to it. also take the front off, and clean the blower assem,bly on the bottom, it is all full of lint, which is why it blew the fuse. tom www.applianceeducator.com/parts.htm:cool:
SublimeMasterJW
#4 Posted : Tuesday, September 1, 2009 5:11:03 AM(UTC)
SublimeMasterJW
UserPostedImage
The large screw that holds down the heating element also holds a clip that keeps the fuse
(thermal limit top right) on the side of the heater chamber. If that blower wheel gets loose or their is a lint buildup then that fuse will blow and kill the dryer.
kayakcrzy
#5 Posted : Tuesday, September 1, 2009 5:13:54 AM(UTC)
kayakcrzy
Originally Posted by: SublimeMasterJW Go to Quoted Post
UserPostedImage
The large screw that holds down the heating element also holds a clip that keeps the fuse on the side of the heater chamber. If that blower wheel gets loose or their is a lint buildup then that fuse will blow and kill the dryer.
There we go. Some more pictures, with instruction. Maybe, I should give the instruction, and you provide the piuctures. I am not a picture guy, but they are awesome with instruction. Keep up the good work. Tom www.applianceeducator.com:cool:
Dryer just stops (Dryer Repair)
by oldblue05 3/10/2013 10:09:02 AM(UTC)
Dryer just stopped (Dryer Repair)
by dfaye61 12/19/2010 10:17:13 AM(UTC)
by tricks 11/8/2010 10:49:00 AM(UTC)
Kenmore dryer just stopped heating (Dryer Repair)
by ssparling 7/20/2010 12:32:32 PM(UTC)
Whirlpool dryer just stopped, quit! (Dryer Repair)
by LindaJ 10/20/2009 4:27:24 AM(UTC)
dryer just stopped working light is on but not turning on (Dryer Repair)
by Elizabeth01 2/28/2009 9:25:56 AM(UTC)
DRYER JUST stoped heating (Dryer Repair)
by rcb21 2/23/2009 12:53:34 PM(UTC)
dryer just stopped running and will not start (Dryer Repair)
by cbailey 2/18/2009 4:00:13 PM(UTC)
by cbailey 2/18/2009 3:58:24 PM(UTC)
Roper dryer just stop turning and just hum. (Dryer Repair)
by waynebowdean 9/6/2008 4:16:08 PM(UTC)
