petewise
#1 Posted : Thursday, January 17, 2008 6:39:56 PM(UTC)
petewise
I have 2 problems
1) I replaced the solanoid for the water and ice dispenser and that seemed to help the icemaker for a day, but the water is still not dispensing. It wil act like it wants to dispense but it seems like there is a clog in the line within the frig. What is your suggestion to fix this problem?
2) I am having a problem with the water freezing in the larger tube going to the icemaker. I have turned the freezer temp down but that does not seem to have an effect on this. I ordered a new icemaker and I hope that the new one will solve this problem. If not, how do I get the water from not freezing in the tube before it gets to the icemaker???
Thanks for your time and answers
abbie
#2 Posted : Friday, January 18, 2008 4:10:20 AM(UTC)
abbie
There,s a service flash on the 106 models --REPAIR TIP..Complaint-..No water from the ice dispenser and/or no ice production.CAUSE..-Cold air coming down the back wall from the diffuser may freeze one or more of the water tubes located in the lower rear of the refrigerator compartment.CORRECTION...-Install tubing insulation and replacement thermostat from Water Tube Insulation Service kit and follow instructions provided..... PARTS..-ORDER PART#4388891,Water Tube INSULATION kIT,DIV46 sourcec646...
LG LDC24370ST Ice Maker Issues (Refrigerator & Freezer Repair)
by Guest 6/29/2024 8:55:44 AM(UTC)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 6/18/2024 8:40:52 AM(UTC)
Water Runs Too Long - Ice maker (Refrigerator & Freezer Repair)
by shfdyoung 6/11/2024 3:01:06 PM(UTC)
Bosch Ice Maker Dropping Ice Once Week (Refrigerator & Freezer Repair)
by Guest 5/31/2024 1:40:51 PM(UTC)
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
Belarus Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
