I have 2 problems
1) I replaced the solanoid for the water and ice dispenser and that seemed to help the icemaker for a day, but the water is still not dispensing. It wil act like it wants to dispense but it seems like there is a clog in the line within the frig. What is your suggestion to fix this problem?
2) I am having a problem with the water freezing in the larger tube going to the icemaker. I have turned the freezer temp down but that does not seem to have an effect on this. I ordered a new icemaker and I hope that the new one will solve this problem. If not, how do I get the water from not freezing in the tube before it gets to the icemaker???
Thanks for your time and answers
There,s a service flash on the 106 models --REPAIR TIP..Complaint-..No water from the ice dispenser and/or no ice production.CAUSE..-Cold air coming down the back wall from the diffuser may freeze one or more of the water tubes located in the lower rear of the refrigerator compartment.CORRECTION...-Install tubing insulation and replacement thermostat from Water Tube Insulation Service kit and follow instructions provided..... PARTS..-ORDER PART#4388891,Water Tube INSULATION kIT,DIV46 sourcec646...
