jcritchl
#1 Posted : Wednesday, August 26, 2009 4:58:29 AM(UTC)
jcritchl
I have a Maytag Plus Side by Side Refridgerator. It has a leak which originates from the defrost drain in the freezer. I tried pouring hot water through the line in case of ice build up but the leak persisted.
I then looked through the back and seen that the seal around the hose connecting to the bottom of the drain looks like it is broken and the water leaks from around the seal. This area is difficult to reach without removing some pieces from near the compressor etc.
How do I go about fixing this? Or do I need to call for service?
Refridgerator leaking water on floor (Refrigerator & Freezer Repair)
by greg2012 8/27/2011 6:54:45 AM(UTC)
Refridgerator leaks and ice builds up in bottum of freezer (Refrigerator & Freezer Repair)
by schweeny 10/27/2010 10:59:54 AM(UTC)
Gibson Frost Clear Top Freezer Refridgerator leaks water periodically (Refrigerator & Freezer Repair)
by kenblarsen 6/17/2009 4:47:46 AM(UTC)
Refridgerator Leaking Water Onto Shelves (Refrigerator & Freezer Repair)
by khudson 9/8/2008 1:12:04 PM(UTC)
Refridgerator leaks at the bottom (Refrigerator & Freezer Repair)
by tomshulski 9/7/2008 2:23:20 PM(UTC)
Refridgerator leaks water (Refrigerator & Freezer Repair)
by Rocky56 7/3/2008 4:56:38 AM(UTC)
Refridgerator Leaking under crispers (Refrigerator & Freezer Repair)
by ltompsen 2/22/2008 7:30:13 AM(UTC)
refridgerator leaks water from inside (Refrigerator & Freezer Repair)
by kmape 7/30/2007 6:10:26 AM(UTC)
