Amamaman
#1 Posted : 16 years ago
Amamaman
When timer is turned to desired time and then pushed in to start, everything starts normally but as soon as you stop pushing in on timer everything stops. Basically it will dry your clothes as long as you stand there pushing in the start knob. Any ideas why? The timer mechanism itself appears to be working, you can hear it clicking away. Thanks for your time!!!
sidfink43
#2 Posted : 16 years ago
sidfink43
Well, it is unfortunate that the push to start mechanism is in the timer, because you have two possibilities here. One is the push to start mechanism, the other is the motor, and both of these are expensive parts. Even worse, the way to tell which is the problem is to replace them.
When the push to start is a separate item, and costs very little I recommend buying it and seeing if that is the problem. In your case you will have to decide how you want to proceed, or it may be the case that a new dryer is in order, and in that situation you know for certain you will have a working machine.
Amamaman
#3 Posted : 16 years ago
Amamaman
Thanks for the reply. All my research in the manuals has led me to the same conclusion. The start to run switch is in fact part of the timer. The motor has a start/run switch that evidently requires replacement of the entire motor. I believe a new dryer IS in order. Thanks again.
sidfink43
#4 Posted : 16 years ago
sidfink43
A good decision I think.
I suggest a basic machine, and that you avoid, if possible, ones with micro processor controls.
Thanks for updating us.
Timer problem? (Washer Repair)
by johnvbf 8 years ago
Whirlpool EHT 201 OLD!!! Defrost Timer Problem? (Refrigerator & Freezer Repair)
by dsoelter 10 years ago
Possible timer problem? (Dryer Repair)
by vorsk 11 years ago
defrost timer problem? (Refrigerator & Freezer Repair)
by BSTrue 12 years ago
Is this a washer timer problem? (Washer Repair)
by hanketron 12 years ago
Timer Problem? (Dryer Repair)
by Grump 12 years ago
Kenmore 600 Series Timer Problem? (Washer Repair)
by fedup352 13 years ago
Maytag washer, timer problem? (Washer Repair)
by Rene' 14 years ago
by butlermom9 14 years ago
Kenmore Electric Dryer - Timer Problem?? (Dryer Repair)
by gus1 14 years ago
Maytag timer problem? (Washer Repair)
by Aaron2010 15 years ago
Timer problem???? (Washer Repair)
by sacto 15 years ago
by tyount 16 years ago
by dpeter33 16 years ago
Timer problem?? (Washer Repair)
by eamiller 17 years ago
