dpeter33
#1 Posted : Monday, June 22, 2009 6:21:43 PM(UTC)
dpeter33
Our Maytag Model A212 washing machine is not advancing properly through the wash cycles. 1/3 of the time it washes correctly through the regular wash, rinse, spin cycles. Otherwise, it will keep advancing through the regular, permanent press, delicate cycles and not stop. Also, when it does stop at whatever point it wants to, it is usually half full of water.
applianceman
#2 Posted : Monday, June 22, 2009 6:45:31 PM(UTC)
applianceman
I would say that the timer has got to be bad.
Clothes Washer Repair Guide
dpeter33
#3 Posted : Monday, June 22, 2009 6:52:31 PM(UTC)
dpeter33
How do I know which timer to order? There seems to be A LOT of them to choose from for this model? Would the existing timer in the washer have a number on it I could use?
applianceman
#4 Posted : Monday, June 22, 2009 7:23:13 PM(UTC)
applianceman
[FONT='Times New Roman']Looks confusing! Next to some of the timers it says needs special attention please call. Make sure you have you model and serial numbers and call I am not sure which one either. [/FONT]
Guest (4)
Maytag timer problem? (Washer Repair)
by Aaron2010 6/24/2010 9:21:34 AM(UTC)
