charlie21ny
#1 Posted : Tuesday, August 25, 2009 3:51:56 PM(UTC)
charlie21ny
this is a gas dryer and it takes 2 cycles for the clothes to dry vent was cleaned out but still takes 2 cycles...the dryer is getting hot. any suggestions.
sidfink43
#2 Posted : Wednesday, August 26, 2009 4:08:12 PM(UTC)
sidfink43
You need to check out the blower and the venting system inside the dryer. It fills up with lint and restricts air flow. Take the dryer apart to do this, and also make sure the blower is working correctly an blowing a strong air flow.
Maytag Neptune clicks/creaks/groans at low spin speeds but not at high speeds (Washer Repair)
by fixitboy 7/3/2024 1:06:24 PM(UTC)
MAYTAG MVWB725BW0 ISSUE (Washer Repair)
by jim hull 6/24/2024 6:25:14 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
Older Maytag won't run (Washer Repair)
by PatAMcD 6/6/2024 12:39:06 PM(UTC)
Maytag vibration after new suspension (Washer Repair)
by Poprox0013 6/5/2024 9:49:34 PM(UTC)
maytag maxima mhw6000aw0 (Washer Repair)
by Guest 5/28/2024 6:30:55 AM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Maytag DE313 Auto Dry malfunction (Dryer Repair)
by DeanEyford 5/5/2024 11:42:21 AM(UTC)
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Maytag throws unbalanced code but spins fine in Drain and Spin mode (Washer Repair)
by Guest 5/3/2024 3:49:04 AM(UTC)
Maytag atlantis half works (Dryer Repair)
by BDR1783 5/3/2024 1:04:26 AM(UTC)
Maytage PYE3300AYW: can't seat drum on new wheels (Dryer Repair)
by Guest 4/26/2024 3:05:06 PM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Maytag Light (Dishwasher Repair)
by Rleblanc 4/22/2024 8:47:19 AM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
