loadster
#1 Posted : Monday, August 6, 2007 4:34:23 AM(UTC)
loadster
My otherxise faultless dw stopped draining. So I checked the drain hose to be sure the outlet into the garbage disposer was clear. Good. Checked drain hoses for crimps or obstruction. Good. Ran self-check diagnostics. No faults except had to manually bail out gallons of water from tank base. Wrestled dw out of cabinet and took extensive on the job training in draining and gaining access to components of dw. Checked resistance on drain motor. Measured 16.5 ohms which indicated good. Checked control board for possible cold solder joints or burnt connections; none found. Finally discovered cover plate over drain impeller in bottom of collector in tank and removed plate. Manually turning sprocket felt like turning sandy blades in bucket of loose bolts and springs. Not smooth. Presumed bearing had failed. Have ordered new pump ($64) and expecting new joys in hand cuts trying to install. Hoping for reincarnated trouble-free dish-maid. Lesson learned: access mechanical shafts on motors and check for free-wheeling when possible. If circulation pump fails, may have to find more serviceable dw.
Admin / APP Team
#2 Posted : Tuesday, August 7, 2007 5:35:13 PM(UTC)
Admin / APP Team
Rank: Administration
:D Nice! From now on you shall be known as "loadster, The Dishwasher Conqueror"! Yeah, I know. That's all I could think of.
Drain pump working intermittently(?) (Dishwasher Repair)
by GRobLewis 6/8/2024 4:45:45 PM(UTC)
Whirlpool Duet MDL# WWF8400TW02 New Drain Pump (Washer Repair)
by 1Oskydoodle! 3/30/2024 10:30:29 AM(UTC)
Noisy LG Drain Pump (Washer Repair)
by Guest 1/13/2023 3:19:30 PM(UTC)
drain pump on lid locked (Washer Repair)
by Randero 7/6/2022 5:32:07 AM(UTC)
LG Washer Drain Pump Noise (Washer Repair)
by Guest 1/28/2022 8:06:10 AM(UTC)
Drain pump for GE front load washing machine (Washer Repair)
by Guest 8/4/2021 6:32:03 AM(UTC)
no wiring diagram for drain pump installation--HELP (Washer Repair)
by TanyaDA 3/17/2021 5:16:46 AM(UTC)
Whirlpool WDT710PAYW6 leaking from underneath drain pump (Dishwasher Repair)
by jcharny 12/15/2020 9:12:46 PM(UTC)
Whirlpool Quiet Partner III GU2400XTPS6 on but only runs the drain pump (Dishwasher Repair)
by misterbrokeit 10/31/2020 1:14:40 PM(UTC)
LG Washer eats drain pumps (Washer Repair)
by Mdavid1955 9/20/2020 1:12:51 PM(UTC)
Just replaced drain pump assembly, now hear a thumping noise (Dishwasher Repair)
by Nowakm716 6/6/2020 5:16:51 AM(UTC)
Samsung FL Washer Replacement rear half tub does not work with existing drain pump location (Washer Repair)
by motoman3 1/14/2020 8:12:15 PM(UTC)
Kenmore Elite washer, no power to drain pump? (Washer Repair)
by David L. Mandel 8/4/2019 10:12:08 PM(UTC)
Drain pump questions. (Dishwasher Repair)
by exaramco 7/4/2019 1:20:15 PM(UTC)
Fisher Paykel Drain Pump Defect? (Washer Repair)
by windsailor 6/17/2019 12:06:24 PM(UTC)
