2 Pages<12
gws001
#11 Posted : Wednesday, August 8, 2007 1:12:20 PM(UTC)
gws001
any other suggestions?
#12 Posted : Wednesday, August 8, 2007 9:22:50 PM(UTC)
gws001
I would check the terminal block on the back of the dryer (were the power cord is connected to the dryer) for burned wires. Also it should be 240V between two hot wires besides 120V between each hot to Neutral. Make sure you have 240V.
gws001
#13 Posted : Friday, August 10, 2007 10:02:11 AM(UTC)
gws001
I have 240 total at terminal block
#14 Posted : Friday, August 10, 2007 1:14:48 PM(UTC)
gws001
You said there is no 240V to the heater. I would recommend to check the power separate between each wire (wires should be disconnected from the heater) and the ground. Probably you'll find a 120V on the one wire and nothing on the another. Trace the wire with no power and see were it's going. The problem is some were there and it could be the timer too but I do not want you to waist money. Let me know your findings.
Be very careful working under the power!
Good luck.
gws001
#15 Posted : Tuesday, August 14, 2007 7:46:40 AM(UTC)
gws001
Thank You
I tried a different timer out of a working unit and still have no heat. I am not sure about checking power separate between each wire. I have a black wire at the heater on one side and the other side comes from the temperature control sensors on the blower and the heating element. With all wires cisconnected on the heating element, I still get continuity through the heating coil. I get separate continuity through eaxh of the temperature controls with the wires disconnected. I also get continuity through them through the heating coil.
gws001
#16 Posted : Tuesday, August 14, 2007 10:02:42 AM(UTC)
gws001
Again Thank YOU
I solved the problem. I checked the wiring diagram and found that the wire that I had mended came off from the motor to the Heating coil, probably while I was working on it. I had to take out the drum to find that it had disconnected at the motor. I reattached it and found heat. However I now need to put it back together. Wish me luck.
gws001
#17 Posted : Tuesday, August 14, 2007 11:54:35 AM(UTC)
gws001
It is back together and working.
THANK YOU**********************
#18 Posted: : Tuesday, August 14, 2007 4:58:51 PM(UTC)
GOOD JOB!
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
by Guest 2/6/2024 1:56:33 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Maytag electric dryer with coin type operation model MDE16CSAYW (Dryer Repair)
by Guest 6/29/2023 9:53:26 AM(UTC)
Maytag electric dryer question (Dryer Repair)
by cramerj 2/15/2021 4:59:49 PM(UTC)
Maytag electric dryer wont start (Dryer Repair)
by HammerSings 3/12/2015 5:22:07 PM(UTC)
Maytag electric dryer takes too long. Troubleshooting guide? Service manual? (Dryer Repair)
by MargretS 11/2/2014 12:08:03 PM(UTC)
Maytag Electric Dryer Light Works But Won't Turn On (Dryer Repair)
by MaytagManNC8 4/11/2014 3:21:09 PM(UTC)
Maytag electric dryer new Thermistor going bad (Dryer Repair)
by derektuan 3/25/2014 5:59:38 PM(UTC)
Maytag electric dryer (Dryer Repair)
by anniepesathor 9/3/2013 6:31:00 AM(UTC)
Maytag electric dryer won't heat (Dryer Repair)
by kspeters 2/6/2013 5:23:47 PM(UTC)
Maytag Electric dryer (Dryer Repair)
by shulskyt 2/6/2013 1:57:13 PM(UTC)
Maytag Electric Dryer won't heat up (Dryer Repair)
by rajpat25 7/7/2012 12:56:23 PM(UTC)
maytag electric dryer runs for 10 min and shuts off (Dryer Repair)
by bearsforme_22 3/8/2012 2:02:11 AM(UTC)
2 Pages<12
