johnwelnetz
#1 Posted : Thursday, August 20, 2009 10:01:49 AM(UTC)
johnwelnetz
Large main burner heats up then cools down and then heats up again but does not remain constant temp. Will I need a new element or???
magician59
#2 Posted : Thursday, August 20, 2009 10:58:56 AM(UTC)
magician59
It's more likely to be the switch.
SKITEXAS
#3 Posted : Sunday, April 14, 2013 9:49:45 AM(UTC)
SKITEXAS
may be the pan , if its not flat it will not relay the temp correctly
Cook top down draft vent (Oven Repair (including Ranges and Cooktops))
by Guest 1/22/2023 4:04:02 PM(UTC)
Jenn-Air Cook Top Gas Range JGC1526ADS15 (Oven Repair (including Ranges and Cooktops))
by patelvi 9/15/2021 1:11:05 PM(UTC)
kitchenAid Gas Cook top shuts off (Oven Repair (including Ranges and Cooktops))
by kkaiser343 12/6/2017 1:42:16 PM(UTC)
Jenn air gas cook top (Oven Repair (including Ranges and Cooktops))
by Mcalee45@gmail.com 4/18/2017 3:56:39 AM(UTC)
Control Panel not working/oven not working/cook top ok (Oven Repair (including Ranges and Cooktops))
by KarenWallace33458 10/20/2016 5:40:57 PM(UTC)
GE Profile gas, cook top glass #940 (Oven Repair (including Ranges and Cooktops))
by edbabcocko1@gmail.com 1/30/2016 9:12:19 AM(UTC)
GE Cook Top / Sparking from under the knob (Oven Repair (including Ranges and Cooktops))
by nj1971 7/8/2015 8:10:45 PM(UTC)
Jenn Air Cook top Low heat (Oven Repair (including Ranges and Cooktops))
by Curban 9/29/2014 12:14:42 PM(UTC)
Cook top works, but neither bake or broil work and both elements are good (Oven Repair (including Ranges and Cooktops))
by Gene Blake 5/31/2014 7:37:02 AM(UTC)
KitchenAid Electric Range Cook Top no power (Oven Repair (including Ranges and Cooktops))
by coachpelkey 4/7/2014 2:39:46 PM(UTC)
by Robin Morgan 11/3/2013 1:13:52 PM(UTC)
replace cook top (Oven Repair (including Ranges and Cooktops))
by brighten 9/13/2013 3:06:54 PM(UTC)
GE cook top (Oven Repair (including Ranges and Cooktops))
by SKITEXAS 4/14/2013 9:06:19 AM(UTC)
Cook top removal (Oven Repair (including Ranges and Cooktops))
by nickh 3/19/2013 5:40:22 AM(UTC)
Removing Cook Top (Oven Repair (including Ranges and Cooktops))
by Dale Paul 2/20/2013 8:20:18 AM(UTC)
