markscoolstuff
#1 Posted : Thursday, August 20, 2009 7:55:10 AM(UTC)
markscoolstuff
My dryer gets very hot on all but the lowest heat setting (Delicates); at that setting, you can just touch it and it is bearable. I just cleaned out the vent tubes when I replaced the rear bearing and they didn't have much of a lining of lint at all. To note: it was getting too hot before I opened it up to replace the bearing.
I suspect a thermostat but this website's parts pages show two are available: AP3210790 (Thermostat-cont-elec w/m.S.) and AP2131477 (thermostat).
Which one should be replaced to fix the problem? If not a thermostat, then what?
magician59
#2 Posted : Thursday, August 20, 2009 11:29:11 AM(UTC)
magician59
The cycling thermostat (the one with two extra wires attached to it) controls the temperature fluctuation. If your dryer doesn't have one of those, it probably has a control board in the console, and a thermistor. The thermistor looks like a thermostat from the outside, but inside the blower or heater housing (depending on its placement), it has a rectangular sensing element. Try cleaning that off and it may work better. Your tech sheet should give you an idea of an acceptable resistance range @ room temperature.
GE Dryer gets too hot (Dryer Repair)
by Bud_Jones 10/8/2014 9:41:09 AM(UTC)
replaced faulty heating element, now dryer gets too hot. Help please! (Dryer Repair)
by sheriowaso 11/15/2013 4:21:37 PM(UTC)
by JoeHipp 6/12/2012 5:12:05 PM(UTC)
Whirlpool GEW9250 dryer gets too hot (Dryer Repair)
by kp1 6/17/2011 2:30:17 PM(UTC)
dryer gets too hot on every heat setting (Dryer Repair)
by jmack123 6/14/2011 3:59:40 AM(UTC)
by bob55 7/25/2010 4:15:18 AM(UTC)
Replaced element, dryer gets too hot (Dryer Repair)
by Piita 6/14/2009 7:48:40 PM(UTC)
Electric dryer gets too hot (Dryer Repair)
by cojo1957 10/27/2008 4:08:44 PM(UTC)
